[gdal-dev] gdalautotest
Alan Stewart
astewart at terragotech.com
Tue Oct 9 12:21:56 PDT 2018
I'd like to run the gdalautotest scripts locally, and add some tests, but I've not had success getting the environment set up correctly. I assume with the right configuration the build process will generate the Python bindings?
I'm on Windows running in a VS1027 x86 native tools command prompt. I've configured the following environment variables:
set "GDAL_HOME=C:\devel\GitHub\build"
set "GDAL_DATA=%GDAL_HOME%\data"
set "PATH=%PATH%;%GDAL_HOME%\bin"
set "PYTHONPATH=C:\devel\GitHub\gdal\gdal\pymod"
My nmake.local contains:
MSVC_VER=1910
VERSION=204
GDAL_HOME="C:\devel\GitHub\build"
PYDIR="C:\Python27" <-- in the PATH inherited by the command prompt
SWIG="C:\devel\GitHub\swig.exe"
BINDINGS=python
HAVE_NUMPY=1
I run "nmake -f makefile.vc", then "nmake -f makefile.vc install", then from the autotest folder "C:\Python27\python.exe run_all.py". The error is that pymod\gdaltest.py cannot import gdal from osgeo.
I found the gdal\swig\python\osgeo folder and tried adding that to PYTHONPATH. Same result.
Alan Stewart
Senior Software Engineer
TerraGo Technologies
3200 Windy Hill Road, Suite 1550W
Atlanta, GA 30339 USA
O. +1 678.391.9615
www.terragotech.com<applewebdata://B24C0762-C7C9-4431-8518-ACC915448B89/www.terragotech.com>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181009/89a9b06d/attachment.html>
