[gdal-dev] gdalautotest
Alan Stewart
astewart at terragotech.com
Tue Oct 9 12:37:45 PDT 2018
Oops, just realized the path I need to add to PYTHONPATH I the parent of osgeo. Still fails importing _gdal. Are these files supposed to have been installed into my Pyton installation by the install process?
Alan Stewart
Senior Software Enginee
TerraGo Technologies
3200 Windy Hill Road, Suite 1550W
Atlanta, GA 30339 USA
O. +1 678.391.9615
www.terragotech.com<applewebdata://B24C0762-C7C9-4431-8518-ACC915448B89/www.terragotech.com>
Sent: Tuesday, October 09, 2018 3:22 PM
To: 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
Subject: gdalautotest
I'd like to run the gdalautotest scripts locally, and add some tests, but I've not had success getting the environment set up correctly. I assume with the right configuration the build process will generate the Python bindings?
I'm on Windows running in a VS1027 x86 native tools command prompt. I've configured the following environment variables:
set "GDAL_HOME=C:\devel\GitHub\build"
set "GDAL_DATA=%GDAL_HOME%\data"
set "PATH=%PATH%;%GDAL_HOME%\bin"
set "PYTHONPATH=C:\devel\GitHub\gdal\gdal\pymod"
My nmake.local contains:
MSVC_VER=1910
VERSION=204
GDAL_HOME="C:\devel\GitHub\build"
PYDIR="C:\Python27" <-- in the PATH inherited by the command prompt
SWIG="C:\devel\GitHub\swig.exe"
BINDINGS=python
HAVE_NUMPY=1
I run "nmake -f makefile.vc", then "nmake -f makefile.vc install", then from the autotest folder "C:\Python27\python.exe run_all.py". The error is that pymod\gdaltest.py cannot import gdal from osgeo.
I found the gdal\swig\python\osgeo folder and tried adding that to PYTHONPATH. Same result.
Alan Stewart
Senior Software Engineer
O. +1 678.391.9615
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181009/0fc3c6da/attachment.html>
