[gdal-dev] Using Spatialite with GDAL 2.3.x
GUIMMARA, Sébastien (External) [FR]
sebastien.guimmara.external at airbus.com
Tue Oct 16 09:38:04 PDT 2018
Hello,
When upgrading from GDAL 2.2.4 to GDAL 2.3.1, loading GDAL/OGR as an SQLite extension doesn't seem to work anymore.
Specifically, using the SQLite C# Wrapper, we do the following steps :
System.Data.SQLite.SQLiteConnection connection = new SQLiteConnection(connectionString);
Connection.Open();
Connection.LoadExtension("gdal230.dll");
Connection.LoadExtension("mod_spatialite.dll");
Then accessing the database using Spatialite causes violation errors. Since this worked with a 2.2.4 build, I wonder. Has something changed around this driver ?
Thanks,
Sébastien
Please consider the environment before printing this email message.
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l'utiliser, ni en divulguer le contenu à quiconque. Merci d'en avertir immédiatement l'expéditeur et d'effacer ce courriel de votre système. Airbus DS Geo décline toute responsabilité en cas de corruptionpar virus, d'altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Airbus DS Geo disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Airbus DS Geo SA (325 089 589 RCS Toulouse) - Siege social: 5, rue des Satellites, 31400 Toulouse, France.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181016/40ed1d4b/attachment.html>
