[gdal-dev] Fillnodata doesn't work correctly with -si parameter
gis_wild dementievda at gmail.com
Wed Oct 17 04:55:26 PDT 2018
Hi all,
I try to fill no data values close to the edge of my single-band raster.
If I set -si parameter values in all the output raster is 0.
I tried to use -nomask parameter as well - it didn't help.
So, what is a proper way to create a new raster file with a filling of no
data values close to the edge of the input raster?
Thank you.
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
