[gdal-dev] GDAL FITS reader support for more than 32-bit signed INT number of pixels?
kingarthur10
arthur.bogard at gmail.com
Wed Oct 24 10:59:45 PDT 2018
Hello All,
I'm trying to read in a large FITS image using the following command:
When I run that, I get the following error:
After some sluething, I can pull in an image up to 65536 x 32768 in size.
One pixel beyond that in a dimension gives me the same error (although the
Y-offset changes based on the size).
It appears that if the total number of pixels exceeds a 32-bit signed
integer, the reader crashes.
Does anyone have ideas on how I can make this work with GDAL? It simplifies
my process a lot, and I ultimately need to output a geotiff from the data.
GDAL is way more efficient than ImageMagick with large image conversions,
and cutting out a step entirely is helpful.
Thanks for any insight!
Arthur
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
