[gdal-dev] GDAL FITS reader support for more than 32-bit signed INT number of pixels?
Even Rouault even.rouault at spatialys.com
Wed Oct 24 11:25:38 PDT 2018
On mercredi 24 octobre 2018 10:59:45 CEST kingarthur10 wrote:
> Hello All,
> I'm trying to read in a large FITS image using the following command:
> When I run that, I get the following error:
> After some sluething, I can pull in an image up to 65536 x 32768 in size.
> One pixel beyond that in a dimension gives me the same error (although the
> Y-offset changes based on the size).
> It appears that if the total number of pixels exceeds a 32-bit signed
> integer, the reader crashes.
Dear King Arthur,
Should be fixed per
https://github.com/OSGeo/gdal/commit/25fc57b7642662356328928a01e3d64ff89eb4c7
Lancelot
http://www.spatialys.com
