[gdal-dev] VRT and COG
Even Rouault
even.rouault at spatialys.com
Fri Oct 26 07:11:35 PDT 2018
On vendredi 26 octobre 2018 09:09:34 CEST Vincent Sarago wrote:
> Goal: I’d like to see if there could be a way to use VRT of COG to create a
> mbtile like system to read tiles.
> If I remember well when a VRT points to COG you still need to create
> external overviews for the whole VRT because it won’t fetch de overviews
> from the COG itself when trying decimated read.
No, that's not exactly true. If a VRT contains more than one source, GDAL
won't be able to expose a proper overview externaly, but it will use the
overviews of sources, when present, for decimated read (*). However if your
VRT has a lot of sources (let's 1024x1024 tiles of 256x256 pixel each), if you
ask for just a 1024x1024 output buffer of the whole extent, there is no magic:
GDAL will have to open each source dataset to compute its contributed single
pixel. In that case, you may want to pregenerate an overview of the whole VRT.
Even
(*) and actually even if those don't expose overviews proper, it will let the
underlying driver handle that at best: so a VRT of VRT of COG would work
http://www.spatialys.com
