[gdal-dev] VRT and COG
Vincent Sarago
vincent.sarago at gmail.com
Fri Oct 26 07:13:17 PDT 2018
Thanks Even ;-)
> Le 26 oct. 2018 à 10:11, Even Rouault <even.rouault at spatialys.com> a écrit :
> On vendredi 26 octobre 2018 09:09:34 CEST Vincent Sarago wrote:
>> Goal: I’d like to see if there could be a way to use VRT of COG to create a
>> mbtile like system to read tiles.
>> If I remember well when a VRT points to COG you still need to create
>> external overviews for the whole VRT because it won’t fetch de overviews
>> from the COG itself when trying decimated read.
> No, that's not exactly true. If a VRT contains more than one source, GDAL
> won't be able to expose a proper overview externaly, but it will use the
> overviews of sources, when present, for decimated read (*). However if your
> VRT has a lot of sources (let's 1024x1024 tiles of 256x256 pixel each), if you
> ask for just a 1024x1024 output buffer of the whole extent, there is no magic:
> GDAL will have to open each source dataset to compute its contributed single
> pixel. In that case, you may want to pregenerate an overview of the whole VRT.
> Even
> (*) and actually even if those don't expose overviews proper, it will let the
> underlying driver handle that at best: so a VRT of VRT of COG would work
> Spatialys - Geospatial professional services
> http://www.spatialys.com
