[gdal-dev] GDAL.NET System.TypeInitializationException
Tamas Szekeres szekerest at gmail.com
Sat Oct 27 07:12:18 PDT 2018
Scott,
Have you called  GdalConfiguration.ConfigureGdal() and/or
GdalConfiguration.ConfigureOgr() at the beginning of your code?
Best regards,
Tamas
Scott Senften <scott at senften.com> ezt írta (időpont: 2018. okt. 26., P,
23:59):
> My apologies; I'm guessing this is well trod ground, but I couldn't find a
> good search for the archives and, on inspection, I couldn't find an
> appropriate topic.
> I'm trying to build one of the GDAL swig c# examples, specifically I have
> tried both OGRGEOS and ORSTransform. I've installed GDAL.NET 2.3.1 from
> nuget (https://www.nuget.org/packages/GDAL.NET/). My projects build but
> both throw System.TypeInitializationException at runtime.
> For OGRGEOS, the error is
>> Exception thrown: 'System.TypeInitializationException' in ogr_csharp.dll
>> An unhandled exception of type 'System.TypeInitializationException'
>> occurred in ogr_csharp.dll
>> The type initializer for 'OSGeo.OGR.OgrPINVOKE' threw an exception.
>> The program '[34872] dotnet.exe' has exited with code -1073741510
>> (0xc000013a).
> I'm guessing that I either have a configuration issue or a dependency
> issue with the underlying native code, but, at this point, I'm just
> guessing.
> Any help would be appreciated,
> Scott
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181027/7d529a86/attachment.html>
