[gdal-dev] GDAL.NET System.TypeInitializationException
Scott Senften
scott at senften.com
Sat Oct 27 11:16:48 PDT 2018
Thank you for quick response.
No, I don't see the configuration calls being used. I'm working from the
examples in the gdal/swig/csharp/apps directory, specifically
https://github.com/OSGeo/gdal/blob/master/gdal/swig/csharp/apps/OGRGEOS.cs
I haven't written any code for myself yet. I'm just trying to confirm I
have a proper dev environment setup using the given demos. Is there a
better starting point for c#/dotnet development? Is there a quick start or
a tutorial that I missed?
Thanks again.
Scott
On Sat, Oct 27, 2018 at 9:12 AM Tamas Szekeres <szekerest at gmail.com> wrote:
> Scott,
> Have you called GdalConfiguration.ConfigureGdal() and/or
> GdalConfiguration.ConfigureOgr() at the beginning of your code?
> Best regards,
> Tamas
> Scott Senften <scott at senften.com> ezt írta (időpont: 2018. okt. 26., P,
> 23:59):
>> My apologies; I'm guessing this is well trod ground, but I couldn't find
>> a good search for the archives and, on inspection, I couldn't find an
>> appropriate topic.
>> I'm trying to build one of the GDAL swig c# examples, specifically I have
>> tried both OGRGEOS and ORSTransform. I've installed GDAL.NET 2.3.1 from
>> nuget (https://www.nuget.org/packages/GDAL.NET/). My projects build but
>> both throw System.TypeInitializationException at runtime.
>> For OGRGEOS, the error is
>>> Exception thrown: 'System.TypeInitializationException' in ogr_csharp.dll
>>> An unhandled exception of type 'System.TypeInitializationException'
>>> occurred in ogr_csharp.dll
>>> The type initializer for 'OSGeo.OGR.OgrPINVOKE' threw an exception.
>>> The program '[34872] dotnet.exe' has exited with code -1073741510
>>> (0xc000013a).
>> I'm guessing that I either have a configuration issue or a dependency
>> issue with the underlying native code, but, at this point, I'm just
>> guessing.
>> Any help would be appreciated,
>> Scott
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181027/09ba37dc/attachment.html>
