[gdal-dev] GDAL.NET System.TypeInitializationException
Tamas Szekeres
szekerest at gmail.com
Sat Oct 27 11:35:06 PDT 2018
Not sure how you project is looking like, I thought you added the GDAL.NET
nuget package as the reference.
Within this package, you can find some code GdalConfiguration.cs, where the
static constructor contains the necessary code to set up the environment
programmatically.
Alternatively you can set the corresponding environment variables manually
on your system so as to get the things working.
Best regards,
Tamas
Scott Senften <scott at senften.com> ezt írta (időpont: 2018. okt. 27., Szo,
20:14):
> Thank you for quick response.
> No, I don't see the configuration calls being used. I'm working from the
> examples in the gdal/swig/csharp/apps directory, specifically
> https://github.com/OSGeo/gdal/blob/master/gdal/swig/csharp/apps/OGRGEOS.cs
> I haven't written any code for myself yet. I'm just trying to confirm I
> have a proper dev environment setup using the given demos. Is there a
> better starting point for c#/dotnet development? Is there a quick start or
> a tutorial that I missed?
> Thanks again.
> Scott
> On Sat, Oct 27, 2018 at 9:12 AM Tamas Szekeres <szekerest at gmail.com>
> wrote:
>> Scott,
>> Have you called GdalConfiguration.ConfigureGdal() and/or
>> GdalConfiguration.ConfigureOgr() at the beginning of your code?
>> Best regards,
>> Tamas
>> Scott Senften <scott at senften.com> ezt írta (időpont: 2018. okt. 26., P,
>> 23:59):
>>> My apologies; I'm guessing this is well trod ground, but I couldn't find
>>> a good search for the archives and, on inspection, I couldn't find an
>>> appropriate topic.
>>> I'm trying to build one of the GDAL swig c# examples, specifically I
>>> have tried both OGRGEOS and ORSTransform. I've installed GDAL.NET 2.3.1
>>> from nuget (https://www.nuget.org/packages/GDAL.NET/). My projects
>>> build but both throw System.TypeInitializationException at runtime.
>>> For OGRGEOS, the error is
>>>> Exception thrown: 'System.TypeInitializationException' in ogr_csharp.dll
>>>> An unhandled exception of type 'System.TypeInitializationException'
>>>> occurred in ogr_csharp.dll
>>>> The type initializer for 'OSGeo.OGR.OgrPINVOKE' threw an exception.
>>>> The program '[34872] dotnet.exe' has exited with code -1073741510
>>>> (0xc000013a).
>>> I'm guessing that I either have a configuration issue or a dependency
>>> issue with the underlying native code, but, at this point, I'm just
>>> guessing.
>>> Any help would be appreciated,
>>> Scott
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181027/539c2a96/attachment.html>
