[gdal-dev] Error: Unable to export GeoTIFF file with different datatypes per different bands. All bands should have the same types in TIFF.
    Schindler, Fabian
    fabian.schindler at eox.at
    Mon Oct 29 03:49:45 PDT 2018
Even,
Thanks for the info. I guess in that case using the highest bit depth will
have to do.
Regarding the nodata value (just curius): how is this value stored (there
is no such tag, AFAIK)? In the GDAL data model this value is per band and
not per dataset, so that could be a possible improvement, right?
Regards,
Fabian
On Mon, 29 Oct 2018 at 11:44, Even Rouault <even.rouault at spatialys.com>
wrote:
> Fabian,
> > I just tried to convert a Cloudsat (2B-GEOPROF to be exact) to a TIFF. I
> > try to do this using the Python bindings and creating a VRT [3]
> referencing
> > the Subdatasets of the HDF 4 file.
> I'd also note that you use different nodata value per band, which isn't
> supported by the GTiff driver.
> > When I try to do this, I get the following error:
> > "Unable to export GeoTIFF file with different datatypes per different
> > bands. All bands should have the same types in TIFF."
> > The TIFF spec allows to define the dataset for each sample ([1] and [2]),
> > but it seems that GDAL does not support it.
> The limitation comes from libtiff itself. Would certainly be a significant
> change in it and in the GDAL GTiff driver.
> You can force all the bands on the highest bit depth.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20181029/9cdeecb8/attachment-0001.html>
