[gdal-dev] Fwd: Missing _gdal_array.py, fail to import in Ubuntu 18.04
Even Rouault
even.rouault at spatialys.com
Mon Sep 3 06:49:20 PDT 2018
(please keep the list cc'ed in your replies)
There's no such file as _gdal_array.py. But there should be a file named like
_gdal_array.cpython-36m-x86_64-linux-gnu.so with the native code of the
binding corresponding to gdal_array.py
Perhaps try make clean before rebuilding
> Hello Even,
> It has been always installed, from pip3, I also tried to build it from
> source.. and still no success. What _gdal_array.py contains that
> gdal_array.py does not? Is it possible to just copy that file from someone
> who has it?
> Imanol
> El lun., 3 sept. 2018 a las 15:17, Even Rouault
> (<even.rouault at spatialys.com>)
> escribió:
> > Imanol,
> > it is likely you need also to install the python-numpy package. The
> > gdal_array.py extension used by ReadAsArray() is only built if numpy is
> > available when the bindings are built.
> > Even
> > > Dear all,
> > > I have been struggling with these for some days. Usually I always build
> > > from source GDAL, it tends to give me better results than install
> > packages.
> > > But this time no, I have tried with `./configure', `./configure
> > > --with-python' and `./configure --with-python=python3.6'. It seems to
> > > compile and work, until I do `ReadAsArray()`, when it complains about
> > > the
> > > missing `_gdal_array.py`. I tried to compile also numpy from source.
> > > I don't write only to ask for a solution, but also to try to understand
> > > what is this file since I can't find much info about it online.
> > > `gdal_array,py` exists, but don't know what the missing one contains.
> > > Thank you
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
