[gdal-dev] gdalwarp together with proj5 pipelines
Dalia Prizginiene dalia at lmi.is
Thu Sep 13 07:51:15 PDT 2018
Hello,
Is it possible to use gdalwarp together with pipelines "+proj=pipeline +step  +inv  +proj=lcc  +lat_1=64...
to transform the raster into different datum?
In here http://osgeo-org.1560.x6.nabble.com/gdal-dev-proj-5-support-added-in-trunk-td5358899.html it is said that "-ct" it could be used. But at the moment this option does not work.
Maybe there is another option how to use gdalwarp together with pipelines of proj5?
Dalia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180913/e2fd46d6/attachment.html>
