[gdal-dev] gdalwarp together with proj5 pipelines
Even Rouault
even.rouault at spatialys.com
Thu Sep 13 08:00:02 PDT 2018
Dalia,
No, this is not yet possible. This is in my todo-list as part of my ongoing
work in PROJ, GDAL, libgeotiff to support WKT2, PROJ5 new features.
For now, you have to use -s_srs / -t_srs with projections method supported by
Even
> Hello,
> Is it possible to use gdalwarp together with pipelines "+proj=pipeline +step
> +inv +proj=lcc +lat_1=64...
> to transform the raster into different datum?
> In here
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-proj-5-support-added-in-trunk-> td5358899.html it is said that "-ct" it could be used. But at the moment
> this option does not work.
> Maybe there is another option how to use gdalwarp together with pipelines of
> proj5?
> Dalia
http://www.spatialys.com
