[gdal-dev] gdalwarp together with proj5 pipelines
Markus Metz
markus.metz.giswork at gmail.com
Thu Sep 13 13:15:41 PDT 2018
On Thu, Sep 13, 2018 at 4:52 PM Dalia Prizginiene <dalia at lmi.is> wrote:
> Hello,
> Is it possible to use gdalwarp together with pipelines "+proj=pipeline
+step +inv +proj=lcc +lat_1=64...
> to transform the raster into different datum?
> In here
http://osgeo-org.1560.x6.nabble.com/gdal-dev-proj-5-support-added-in-trunk-td5358899.html
it is said that "-ct" it could be used. But at the moment this option does
not work.
> Maybe there is another option how to use gdalwarp together with pipelines
of proj5?
Custom proj5-style pipelines are supported in GRASS 7.6, not yet released.
GRASS uses GDAL + PROJ for reprojection, and any testing on this new
feature would help those projects.
In GRASS 7.6, you can define custom proj5-pipelines with r.proj pipeline=...
Markus M
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20180913/ea7829a5/attachment.html>
