[gdal-dev] ogr2ogr - id field in database table is not being written to geojson file
David McKelvie dmck at interactive.co.uk
Fri Sep 14 08:25:27 PDT 2018
Hi;
I have a question about ogr2ogr output from a postgres database to geojson.
One of the fields in my table, ie the primary key called 'id' is not being
output to the json file. I wonder if this is a bug or a 'feature'.
Can anybody clarify this?
The database table is:
\d areas
              Table "public.areas"
      Column       |            Type
 id                | integer
 type              | character varying(31)
 name              | character varying(255)
 created           | timestamp without time zone
 last_modified     | timestamp without time zone
 location          | geometry(Geometry,27700)
 is_deleted        | boolean
 ons_code          | character varying(9)
 extended_location | geometry(Geometry,27700)
 uprn              | character varying(12)
 info              | text
 name_vector       | tsvector
The command run was:
ogr2ogr -f "GeoJSON" \
-lco "COORDINATE_PRECISION=2" \
/tmp/divisions.json \
"PG:dbname=capetown" areas
The output file /tmp/divisions.json
had entries with properties like:
properties": {
   "type": "division",
   "name": "Divn  01",
   "created": "2018\/09\/14 12:19:41",
   "last_modified": "2018\/09\/14 12:19:41",
   "is_deleted": 0,
   "ons_code": null,
   "uprn": null,
   "info": null,
   "name_vector": "'01':2 'divn':1"
So all the database table fields EXCEPT for
the geometry fields and 'id' which is defined as
    id | integer | not null default nextval('areas_id_seq'::regclass)
and is the primary key for the table.
https://www.gdal.org/drv_geojson.html does not mention anything special about
'id' or primary key fields.
I am using ogr2ogr on Ubuntu Linux from the gdal-bin package . version 1.11.3+dfsg-3build2
David McKelvie
