[gdal-dev] Python GDAL ImportError: ... undefined symbol: CPLGetErrorCounter
Chiara Marmo chiara.marmo at u-psud.fr
Fri Sep 14 08:57:11 PDT 2018
> Sounds like either you lack the libgdal.so in your library search path, or it
> is an older version of it. You can tune that with LD_LIBRARY_PATH for example
Right, but no matter I define LD_LIBRARY_PATH jupyter always look in /usr/lib64 (on Fedora).
So I've solved the issue linking my version in /usr/lib64 ... not clean but effective .. :)
Thanks!
Chiara
Chiara Marmo
Ingénieur de Recherche GEOPS - Paris Sud-11
Bât 509
Tel: +33 (0)1 69 15 49 03
