[gdal-dev] showing vertical datum in wgs84 or its variants
Michael Smith
michael.smith.erdc at gmail.com
Sat Sep 15 11:36:25 PDT 2018
All,
If I have a DEM with a vertical datum that is not wgs84, it shows properly in gdal. For example,
COMPD_CS["WGS 84 / UTM zone 51N + EGM2008 geoid height",
PROJCS["WGS 84 / UTM zone 51N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",123],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","32651"]],
VERT_CS["EGM2008 geoid height",
VERT_DATUM["EGM2008 geoid",2005,
EXTENSION["PROJ4_GRIDS","egm08_25.gtx"],
AUTHORITY["EPSG","1027"]],
UNIT["metre",1,
AXIS["Up",UP],
AUTHORITY["EPSG","3855"]]]
If I then project this to WGS84 vertical, it does display as a vrt.
gdalwarp -of vrt -t_srs epsg:32651+7662 myfile.tif myfile_wgs.vrt
Coordinate System is:
COMPD_CS["WGS 84 / UTM zone 51N + WGS 84 (G1674)",
GEOGCS["WGS 84",
DATUM["WGS_1984",
UNIT["metre",1,
GEOCCS["WGS 84 (G1674)",
DATUM["World_Geodetic_System_1984_G1674",
AUTHORITY["EPSG","1155"]],
UNIT["metre",1,
AXIS["Geocentric X",OTHER],
AXIS["Geocentric Y",OTHER],
AXIS["Geocentric Z",NORTH],
AUTHORITY["EPSG","7662"]]]
(and the z values do get properly projected). But when I convert from vrt to geotiff,
gdal_translate -of gtiff myfile_wgs.vrt myfile_wgs.tif
It no longer shows the compd_cs
GEOGCS["WGS 84",
DATUM["WGS_1984",
UNIT["metre",1,
I do have the environmental variable set to always show a compd_cs, GTIFF_REPORT_COMPD_CS=TRUE
Is this a special wgs simplification that gdal does on the vertical datum?
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
