[gdal-dev] showing vertical datum in wgs84 or its variants
Even Rouault
even.rouault at spatialys.com
Sat Sep 15 14:32:59 PDT 2018
Michael,
> Coordinate System is:
> COMPD_CS["WGS 84 / UTM zone 51N + WGS 84 (G1674)",
> PROJCS["WGS 84 / UTM zone 51N",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",123],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","32651"]],
> GEOCCS["WGS 84 (G1674)",
> DATUM["World_Geodetic_System_1984_G1674",
> AUTHORITY["EPSG","1155"]],
> UNIT["metre",1,
> AXIS["Geocentric X",OTHER],
> AXIS["Geocentric Y",OTHER],
> AXIS["Geocentric Z",NORTH],
> AUTHORITY["EPSG","7662"]]]
> (and the z values do get properly projected). But when I convert from vrt to
> geotiff,
EPSG:32651+7662 is an invalid CRS. The vertical part should be a vertical
CRS, and not a Geocentric CRS as here.
GDAL / VRT is forgiving, but there's no way to encode this in GeoTIFF.
There's no way in WKT 1 to model a ProjectedCRS with a ellipsoidal height
(WKT 2:2018 will allow it with the concept of Projected 3D CRS),
so using plain EPSG:32651 is your best option here.
Actually I lied... There would be a way, but it is definitely not recommended.
The historical GeoTIFF spec allows for "ellipsoid Vertical CS"
( http://geotiff.maptools.org/spec/geotiff6.html#6.3.4 ), but ISO 19111 does
not allow this, and this will be likely no longer available as it in a future
revision of the GeoTIFF spec.
So if using listgeo to dump the TIFF you want to fix, and you insert the following in the
Keyed_Information section of the listgeo dump
GTCitationGeoKey (Ascii,45): "WGS 84 / UTM zone 31N + WGS84 ellipsoid height"
VerticalCSTypeGeoKey (Short,1): VertCS_WGS_84_ellipsoid
VerticalUnitsGeoKey (Short,1): Linear_Meter
and then using geotifcp -g to forge a new GeoTIFF file, you will get
COMPD_CS["WGS 84 / UTM zone 31N + WGS 84 ellipsoid height",
GEOGCS["WGS 84",
DATUM["WGS_1984",
UNIT["metre",1,
VERT_CS["unknown",
VERT_DATUM["Not specified (based on WGS 84 ellipsoid)",2002,
AUTHORITY["EPSG","6030"]],
UNIT["metre",1.0,
AXIS["Up",UP]]]
But this would be considered as invalid as well by today's standards.
(EPSG:6030 is not a vertical datum, but a geodetic datum)
Even
http://www.spatialys.com
