[gdal-dev] installing gdal in CentOS
Andrew C Aitchison
andrew at aitchison.me.uk
Mon Apr 1 14:12:13 PDT 2019
On Mon, 1 Apr 2019, Markus Neteler wrote:
> Now I am stuck at
> BUILD SUCCESSFUL
> Total time: 10 seconds
> + popd
> + %mvn_artifact swig/java/build/maven/gdal-2.3.2.pom
> swig/java/build/maven/gdal-2.3.2.jar
> ~/build/BUILD/gdal-2.3.2-fedora
> /var/tmp/rpm-tmp.R4QpDm: line 139: fg: no job control
> error: Bad exit status from /var/tmp/rpm-tmp.R4QpDm (%build)
That is probably a bug in the rpm .spec file
https://www.redhat.com/archives/rpm-list/2002-October/msg00271.html
suggests that it is a % character being passed to the shell.
Andrew C. Aitchison Cambridge, UK
