[gdal-dev] installing gdal in CentOS
Markus Neteler
neteler at osgeo.org
Fri Apr 5 06:38:28 PDT 2019
On Mon, Apr 1, 2019 at 11:17 PM Andrew C Aitchison
<andrew at aitchison.me.uk> wrote:
> On Mon, 1 Apr 2019, Markus Neteler wrote:
> > Now I am stuck at
> > BUILD SUCCESSFUL
> > Total time: 10 seconds
> > + popd
> > + %mvn_artifact swig/java/build/maven/gdal-2.3.2.pom
> > swig/java/build/maven/gdal-2.3.2.jar
> > ~/build/BUILD/gdal-2.3.2-fedora
> > /var/tmp/rpm-tmp.R4QpDm: line 139: fg: no job control
> > error: Bad exit status from /var/tmp/rpm-tmp.R4QpDm (%build)
> That is probably a bug in the rpm .spec file
> https://www.redhat.com/archives/rpm-list/2002-October/msg00271.html
> suggests that it is a % character being passed to the shell.
Thanks Andrew,
I made further attempts but I am stuck.
Maybe the Python-3 support needs to be kicked out as well?
The current state is here
https://copr.fedorainfracloud.org/coprs/neteler/GDAL/build/876548/
- SPEC file: https://copr-be.cloud.fedoraproject.org/results/neteler/GDAL/epel-7-x86_64/00876548-gdal/gdal.spec
- Log file: https://copr-be.cloud.fedoraproject.org/results/neteler/GDAL/epel-7-x86_64/00876548-gdal/builder-live.log
I'll continue with low priority, happily accepting support by
more-than-me SPEC file experts.
Best,
Markus
