Hello, If I build overviews for dataset which doesn't have one, overviews will be generated in separate file such as .ovr which will be saved in the same folder as source dataset file. Can I change location of generated overviews to different folder? -- Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
