[gdal-dev] Overviews default directory
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Fri Apr 5 03:54:43 PDT 2019
You can read the images through a VRT file
https://www.gdal.org/gdal_vrttut.html that includes an overview element with
an absolute path.
"Overview: This optional element describes one overview level for the band.
It should have a child SourceFilename and SourceBand element. The
SourceFilename may have a relativeToVRT boolean attribute. Multiple elements
may be used to describe multiple overviews."
<Overview>
<SourceFilename relativeToVRT="0">path/to/image.ovr</SourceFilename>
<SourceBand>1</SourceBand>
</Overview>
-Jukka Rahkonen-
Zaraka wrote
> Hello,
> If I build overviews for dataset which doesn't have one, overviews will be
> generated in separate file such as .ovr which will be saved in the same
> folder as source dataset file.
> Can I change location of generated overviews to different folder?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
