[gdal-dev] Gdal_fusion.py???
Markus Neteler neteler at osgeo.org
Fri Apr 5 16:18:44 PDT 2019
I wrote some scripts to colorize point cloud provided as XYZ files using
PDAL:
https://github.com/mundialis/openNRW/blob/master/lidar/README.md
Maybe to get some ideas ...
Markus
Nicolas Cadieux <nicolas.cadieux at archeotec.ca> schrieb am Fr., 5. Apr.
2019, 23:14:
> Hi,
> I will read up on the PDAL colorize.  For now, my only input is a txt file
> therefore I am not using PDAL nor am I using gdal to read the cloud.  I
> must admit, I am not too good with using PDAL but I would like to.  I do
> use gdal to read the rasters.  For now, the main purpose was to use it with
> HSI taken from drones but I have someone trying it with a ground based
> scanner.  Does PDAL colonize handle any number of bands?
> Nicolas
> Le 5 avr. 2019 à 15:52, Luigi Pirelli <luipir at gmail.com> a écrit :
> Hi Nicolas,
> really interesting... it is suitable only for pointcloud from airborne
> sensors or also from mobil? Is it different from 'pdal colorize' command
> [1]?
> Luigi Pirelli
> [1] https://pdal.io/stages/filters.colorization.html#filters-colorization
>  and
> https://pdal.io/workshop/exercises/analysis/colorization/colorization.html
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> * Hire me: http://goo.gl/BYRQKg
> On Fri, 5 Apr 2019 at 21:27, Nicolas Cadieux <nicolas.cadieux at archeotec.ca>
> wrote:
>> Hi,
>> I have made a python 2.7 / 3.7 program to fuse a point cloud with
>> hyperspectral images.  The end result is a text file with xyz... from the
>> cloud file followed by the band pixel values.  It’s all multithreaded so a
>> cloud with 6.5 million points can be fused with a raster with 288 band in
>> 45min (12 threads). What would it take to make this an official gdal
>> command line utility? What steps would be involved?
>> Nicolas
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190406/1434313e/attachment-0001.html>
