[gdal-dev] How to run autotest
Even Rouault even.rouault at spatialys.com
Thu Apr 18 10:26:00 PDT 2019
On jeudi 18 avril 2019 16:41:41 CEST John Daniel wrote:
> Even,
> scripts/setdevenv.sh did fix the python problem for me.
> However, I get a very similar segfault in the test scripts that I get on the
> Mac. It seems related to SQLite and SpatiaLite. I'm going to try to rebuild
> with an older set of GDAL+libs that has worked in the past.
> Here is the backtrace if anyone is curious. Unless anyone recognizes a known
> issue, I'm assuming this is my problem to work out from here.
Does not ring a bell. But from the stack trace, you're not using a recent
spatialite version. Perhaps upgrading it would be a good idea.
http://www.spatialys.com
