[gdal-dev] How to run autotest
Even Rouault even.rouault at spatialys.com
Thu Apr 18 12:00:20 PDT 2019
> Not sure how you find out I used libtool build. In my configure option,
> I did specify "--without-libtool".
/scratch/gdal/gdal/gdal/.libs/libgdal.so.20 is a file produced by a libtool
build. You perhaps did initially a libtool build and then a non-libtool one.
Remove /scratch/gdal/gdal/gdal/.libs
http://www.spatialys.com
