[gdal-dev] How to run autotest
Fengting Chen fengting.chen at oracle.com
Fri Apr 19 12:36:33 PDT 2019
Removing .libs helped and now pytest is working. Thank you!
Instead of using pytest to run all the tests, how to run individual test?
On 4/18/2019 3:00 PM, Even Rouault wrote:
>> Not sure how you find out I used libtool build. In my configure option,
>> I did specify "--without-libtool".
> /scratch/gdal/gdal/gdal/.libs/libgdal.so.20 is a file produced by a libtool
> build. You perhaps did initially a libtool build and then a non-libtool one.
> Remove /scratch/gdal/gdal/gdal/.libs
