[gdal-dev] GDAL 2.5.0 beta1 available
Greg Troxel
gdt at lexort.com
Fri Apr 19 07:08:20 PDT 2019
Even Rouault <even.rouault at spatialys.com> writes:
> GDAL 2.5.0 *requires* PROJ >= 6.0, and if using external libgeotiff,
I would expect then that packaging systems will hold off on this,
because I don't think we've reached the point that the collateral damage
of upgrading proj to 6 is ok.
With any luck I'm wrong and most of the proj-using packages have had a
release that works on 6, but it seems that there are a lot of packages
not yet able to cope.
(Which is all fine; packaging systems can stay on 2.4.x for a while.)
