[gdal-dev] ASCII Gridded XYZ and "Hectare Raster" data (STATPOP and STATENT)
Stefan Keller sfkeller at gmail.com
Mon Apr 22 14:49:28 PDT 2019
Even,
As said my point input data already has regular, constant spaces,
namely 100 meters in X and Y, with e.g. extent (2661900, 1253800) -
(2668400, 1261300), map units are meters (SRS EPSG:2056).
I managed to convert my data using following gdal_grid command
> gdal_grid -ot UInt16 -of GTiff -zfield "C1" in.gpkg out.tif
Now I still have an issue with the output pixel size which was
27.41341571800429122,-27.41341571800429122 meters
But what I want is a pixel size with exactly same spacing as input
points, namely 100,-100 (meters).
I know there's the gdal_grid options -txe/-tye/-outsize, but I'd like
to avoid calculating these by hand.
In addition IMHO there's no need interpolation at all (or nearest
neighbor at most), since input point is already in place, ready for
output.
Is there a solution for just setting output pixel size in map units
(or am I missing something)?
:Stefan
Am So., 21. Apr. 2019 um 14:48 Uhr schrieb Stefan Keller <sfkeller at gmail.com>:
> Hi Even
> Thx very much!
> I'll try that way and will report.
> :Stefan
> Am So., 21. Apr. 2019 um 11:31 Uhr schrieb Even Rouault
> <even.rouault at spatialys.com>:
> > Stefan,
> > > The Swiss Statistical Office curates well-known datasets informally
> > > called "Hectare Raster" (STATPOP and STATENT) which obviously are
> > > ASCII Gridded XYZ, like this:
> > > "RELI" "X" "Y" "C1" "C2" "C3"
> > > 66192542 661900 254200 1 2 3 ...
> > > 66192543 661900 254300 1 2 3 ...
> > > 66192599 661900 259900 1 2 3 ...
> > > 66192600 661900 260000 1 2 3 ...
> > > This obviously is a regular gridded X and Y, sorted by X,Y but
> > > obviously also has gaps and more than one  "Z" (C1, C2, C3). Typically
> > > this is converted to a raster format like GeoTIFF and analysed through
> > > map algebra.
> > > Question 1: The GDAL docs (https://www.gdal.org/frmt_xyz.html ) says
> > > "...no missing value is supported.". In fact, I think it supports them
> > > by omitting lines by setting missing "lines" to NODATA.
> > > => Correct?
> > The driver is quite picky. I don't think it will support missing values in the
> > middle of a line of same Y value. It supports missing values at the beginning
> > or end of a line of same Y value. And points must be sorted by increasing or
> > decreasing Y, and increasing X value for a line of same Y value.
> > > Question 2: I think, there is a way (which could be mentioned in the
> > > docs above), to determine the "Z" value to be converted by gdal_grid
> > > explained in "Reading comma separated values"
> > > (https://www.gdal.org/gdal_grid.html#gdal_grid_csv ).
> > > So XYZ in fact is XYZx meaning that potentially there can be many "Z"
> > > in the input file, but only one can be included.
> > > => What do you think?
> > The best way might probably to read the file with the CSV driver indeed. With
> > CSV:the_filename if the_filename has not a .csv extension
> > Convert it to something with a spatial index like a shapefile or GPKG if the
> > file is big
> > And then use gdal_grid to create a raster from it.
> > > Question 3 (the fundamental one): Although XYZ format requires to
> > > contain regular gridded coordinates, it's technically handled the same
> > > as irregular coordinates (without interpolation) - at least regarding
> > > the main task to convert an sparse array of values to a raster format.
> > > => Correct?
> > The XYZ driver requires constant spacing.
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
