[gdal-dev] ASCII Gridded XYZ and "Hectare Raster" data (STATPOP and STATENT)
Stefan Keller
sfkeller at gmail.com
Wed Apr 24 15:26:35 PDT 2019
Am 22. Apr. 2019 23:49 wrote regarding gdal_grid:
> Is there a solution for just setting output pixel size in map units
By guessing the "-outsize 65 75" (no. of X and Y lines) I finally got
a result which contained a pixel size of 100, -100 meters plus
sensible values:
# gdal_grid -ot UInt16 -of GTiff -zfield "C3" -a
nearest:radius1=71:radius2=71 -outsize 65 75 in.gpkg out.tif
=> But, I'm still looking for a hint to set pixel sizes without
guessing or calculating the "outsize" from the extents of the input
file.
Then, I observed another problem: One obviously has no choice in
gdal_grid than to choose an interpolation method. As one can see from
the command above, I've chosen "nearest neighbour" as interpolation
method (option "-a nearest:radius1=71:radius2=71").
Now, this worked somehow - but not exactly: In almost all cases a
single input grid point (which "sits" at the junction of four pixels)
affected two or three neighboring pixels in the raster output.
=> But what I'm after is, that one input grid point only sets the
value of one pixel (say lower left pixel) in the raster output!
Which "neighboring" pixel exactly is of secondary importance here.
Main point is that one input value maps to only _one_ (not many) pixel
:Stefan
Am Mo., 22. Apr. 2019 um 23:49 Uhr schrieb Stefan Keller <sfkeller at gmail.com>:
> Even,
> As said my point input data already has regular, constant spaces,
> namely 100 meters in X and Y, with e.g. extent (2661900, 1253800) -
> (2668400, 1261300), map units are meters (SRS EPSG:2056).
> I managed to convert my data using following gdal_grid command
> > gdal_grid -ot UInt16 -of GTiff -zfield "C1" in.gpkg out.tif
> Now I still have an issue with the output pixel size which was
> 27.41341571800429122,-27.41341571800429122 meters
> But what I want is a pixel size with exactly same spacing as input
> points, namely 100,-100 (meters).
> I know there's the gdal_grid options -txe/-tye/-outsize, but I'd like
> to avoid calculating these by hand.
> In addition IMHO there's no need interpolation at all (or nearest
> neighbor at most), since input point is already in place, ready for
> output.
> (or am I missing something)?
> :Stefan
> Am So., 21. Apr. 2019 um 14:48 Uhr schrieb Stefan Keller <sfkeller at gmail.com>:
> > Hi Even
> > Thx very much!
> > I'll try that way and will report.
> > :Stefan
> > Am So., 21. Apr. 2019 um 11:31 Uhr schrieb Even Rouault
> > <even.rouault at spatialys.com>:
> > > Stefan,
> > > > The Swiss Statistical Office curates well-known datasets informally
> > > > called "Hectare Raster" (STATPOP and STATENT) which obviously are
> > > > ASCII Gridded XYZ, like this:
> > > > "RELI" "X" "Y" "C1" "C2" "C3"
> > > > 66192542 661900 254200 1 2 3 ...
> > > > 66192543 661900 254300 1 2 3 ...
> > > > 66192599 661900 259900 1 2 3 ...
> > > > 66192600 661900 260000 1 2 3 ...
> > > > This obviously is a regular gridded X and Y, sorted by X,Y but
> > > > obviously also has gaps and more than one "Z" (C1, C2, C3). Typically
> > > > this is converted to a raster format like GeoTIFF and analysed through
> > > > map algebra.
> > > > Question 1: The GDAL docs (https://www.gdal.org/frmt_xyz.html ) says
> > > > "...no missing value is supported.". In fact, I think it supports them
> > > > by omitting lines by setting missing "lines" to NODATA.
> > > > => Correct?
> > > The driver is quite picky. I don't think it will support missing values in the
> > > middle of a line of same Y value. It supports missing values at the beginning
> > > or end of a line of same Y value. And points must be sorted by increasing or
> > > decreasing Y, and increasing X value for a line of same Y value.
> > > > Question 2: I think, there is a way (which could be mentioned in the
> > > > docs above), to determine the "Z" value to be converted by gdal_grid
> > > > explained in "Reading comma separated values"
> > > > (https://www.gdal.org/gdal_grid.html#gdal_grid_csv ).
> > > > So XYZ in fact is XYZx meaning that potentially there can be many "Z"
> > > > in the input file, but only one can be included.
> > > > => What do you think?
> > > The best way might probably to read the file with the CSV driver indeed. With
> > > CSV:the_filename if the_filename has not a .csv extension
> > > Convert it to something with a spatial index like a shapefile or GPKG if the
> > > file is big
> > > And then use gdal_grid to create a raster from it.
> > > > Question 3 (the fundamental one): Although XYZ format requires to
> > > > contain regular gridded coordinates, it's technically handled the same
> > > > as irregular coordinates (without interpolation) - at least regarding
> > > > the main task to convert an sparse array of values to a raster format.
> > > > => Correct?
> > > The XYZ driver requires constant spacing.
> > > Even
> > > Spatialys - Geospatial professional services
> > > http://www.spatialys.com
