[gdal-dev] [EXTERNAL] Change an image from 0-360 to -180 to 180
Hare, Trent
thare at usgs.gov
Wed Apr 24 16:27:01 PDT 2019
Maghan,
I prefer the VRT method (near the end of this page
<http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial>) which I use
all the time, but this page (listed next, which also lists this VRT method)
has a couple other options:
https://gis.stackexchange.com/questions/37790/how-to-reproject-raster-from-0-360-to-180-180-with-cutting-180-meridian
good luck,
Trent
On Wed, Apr 24, 2019 at 4:16 PM Meghan Burris <emmburris at gmail.com> wrote:
> Hello,
> I have an image that is 0-360 degrees but I want to visualize it in -180
> to 180 degrees. Everything I try makes the western hemisphere (-180-0)
> completely black, so half the map doesn't get displayed. Any chance there
> is an easy fix to this?
> Thank you so much for any help!
> - Em
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190424/2bccd024/attachment-0001.html>
