[gdal-dev] [EXTERNAL] Change an image from 0-360 to -180 to 180
Meghan Burris
emmburris at gmail.com
Wed Apr 24 16:54:10 PDT 2019
Thanks Trent!
I'll take a look at that right now. I appreciate your help.
On Wed, Apr 24, 2019 at 4:27 PM Hare, Trent <thare at usgs.gov> wrote:
> Maghan,
> I prefer the VRT method (near the end of this page
> <http://trac.osgeo.org/gdal/wiki/UserDocs/RasterProcTutorial>) which I
> use all the time, but this page (listed next, which also lists this VRT
> method) has a couple other options:
> https://gis.stackexchange.com/questions/37790/how-to-reproject-raster-from-0-360-to-180-180-with-cutting-180-meridian
> good luck,
> Trent
> On Wed, Apr 24, 2019 at 4:16 PM Meghan Burris <emmburris at gmail.com> wrote:
>> Hello,
>> I have an image that is 0-360 degrees but I want to visualize it in -180
>> to 180 degrees. Everything I try makes the western hemisphere (-180-0)
>> completely black, so half the map doesn't get displayed. Any chance there
>> is an easy fix to this?
>> Thank you so much for any help!
>> - Em
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190424/8f6e4eb1/attachment.html>
