[gdal-dev] UK Ordnance Survey grid references
Paul Meems bontepaarden at gmail.com
Sat Apr 27 08:09:51 PDT 2019
I'm not sure if this is the correct list, it might be I need to ask this on
the proj4-list.
Because I'm not a member of that list, I try here first.
Can GDAL/OGR/Proj4 convert lat/long coordinates to Ordnance Survey grid
references?
I've been searching for an answer and found only this page:
https://digimap.edina.ac.uk/webhelp/digimapgis/projections_and_transformations/transformations_in_gdalogr.htm
suggesting
it is possible with GDAL after some changes.
But I can't find an example of how to convert '-2.02903211116781,
53.4040442788744' to 'SJ981896'.
Is this possible with GDAL? If so do I still make the changes mentioned on
the webpage and how would the code look like to do this?
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190427/ac1b7e4c/attachment.html>
