[gdal-dev] Interesting debugging log from FileGBD driver
Andrea Aime andrea.aime at geo-solutions.it
Tue Apr 30 06:33:22 PDT 2019
On Tue, Apr 30, 2019 at 3:22 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> What is slow exactly ? The first time you do a spatial filtering (which is
> expected, since it requires to do a full scan of the file, because the
> driver
> doesn't know how to use the on-disk spatial index), or later spatial
> filtering
> operations with the connection still opened (which should be fast
> normally) ?
Oh wait! You mean those messages pop up only if OpenFileGDB is used?
Dang, thought I had forced usage of FileGBD but I did not, very sorry for
the noise.
The log messages are gone, performance is still really bad. Can I blame
multithreading for that?
All the datasource objects are opened in read only mode
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39
0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
http://www.geo-solutions.it http://twitter.com/geosolutions_it
------------------------------------------------------- *Con riferimento
alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto, gli eventuali
allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
sarei comunque grato se potesse darmene notizia. This email is intended
only for the person or entity to which it is addressed and may contain
information that is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European Regulation 2016/679
“GDPR” - copying, dissemination or use of this e-mail or the information
herein by anyone other than the intended recipient is prohibited. If you
have received this email by mistake, please notify us immediately by
telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190430/27cdc92e/attachment-0001.html>
