[gdal-dev] Interesting debugging log from FileGBD driver
Even Rouault even.rouault at spatialys.com
Tue Apr 30 06:41:00 PDT 2019
On mardi 30 avril 2019 15:33:22 CEST Andrea Aime wrote:
> On Tue, Apr 30, 2019 at 3:22 PM Even Rouault <even.rouault at spatialys.com>
> wrote:
> > What is slow exactly ? The first time you do a spatial filtering (which is
> > expected, since it requires to do a full scan of the file, because the
> > driver
> > doesn't know how to use the on-disk spatial index), or later spatial
> > filtering
> > operations with the connection still opened (which should be fast
> > normally) ?
> Oh wait! You mean those messages pop up only if OpenFileGDB is used?
> Dang, thought I had forced usage of FileGBD but I did not, very sorry for
> the noise.
> The log messages are gone, performance is still really bad. Can I blame
> multithreading for that?
> All the datasource objects are opened in read only mode
Ah, the FileGDB SDK used by the FileGDB driver was/is not thread-safe, so the
FileGDB driver holds a global lock...
Even
http://www.spatialys.com
