[gdal-dev] Requirements for GPKG support in ogr2ogr build?
WhiskyPiper67
whiskypiper67 at yahoo.com
Thu Aug 8 20:07:04 PDT 2019
Hi there,
Real basic question here, I hope (but it's got me worried because I expected to find the answer in doco or discussion...)
I am building GDAL 2.3.2 on RHEL 7.
I have installed a couple of the drivers and libraries I require for my build (Oracle, PostGIS) and now I'm trying to get GeoPackage GPKG support.
What exactly are the pre-requisite installs for this? I've installed some extra rpm packages, based upon a bit of scratching around, but I'm missing the secret sauce to get the all-important:
GPKG -raster,vector- (rw+vs): GeoPackage
.. in my "ogr2ogr --formats" list
Thanks in anticipation!
Dave
------------------------Recent package installs (trying to light up GPKG support)
sudo yum install sqlite sqlite-devel
Installed PackagesName : sqlite-develArch : x86_64Version : 3.7.17Release : 8.el7Size : 366 kRepo : installedFrom repo : rhui-REGION-rhel-server-releasesSummary : Development tools for the sqlite3 embeddable SQL database engineURL : http://www.sqlite.org/License : Public DomainDescription : This package contains the header files and development documentation : for sqlite. If you like to develop programs using sqlite, you will need : to install sqlite-devel.
Installed PackagesName : sqliteArch : x86_64Version : 3.7.17Release : 8.el7Size : 795 kRepo : installedFrom repo : anacondaSummary : Library that implements an embeddable SQL database engineURL : http://www.sqlite.org/License : Public DomainDescription : SQLite is a C library that implements an SQL database engine. A large : subset of SQL92 is supported. A complete database is stored in a : single disk file. The API is designed for convenience and ease of use. : Applications that link against SQLite can enjoy the power and : flexibility of an SQL database without the administrative hassles of : supporting a separate database server. Version 2 and version 3 binaries : are named to permit each to be installed on a single host
sudo yum install libspatialite libspatialite-devel
Installed PackagesName : libspatialiteArch : x86_64Version : 4.1.1Release : 2.el7Size : 4.0 MRepo : installedFrom repo : epelSummary : Enables SQLite to support spatial dataURL : https://www.gaia-gis.it/fossil/libspatialiteLicense : MPLv1.1 or GPLv2+ or LGPLv2+Description : SpatiaLite is a a library extending the basic SQLite core : in order to get a full fledged Spatial DBMS, really simple : and lightweight, but mostly OGC-SFS compliant.
Installed PackagesName : libspatialite-develArch : x86_64Version : 4.1.1Release : 2.el7Size : 432 kRepo : installedFrom repo : epelSummary : Development libraries and headers for SpatiaLiteURL : https://www.gaia-gis.it/fossil/libspatialiteLicense : MPLv1.1 or GPLv2+ or LGPLv2+Description : The libspatialite-devel package contains libraries and header files for : developing applications that use libspatialite.
_______________________________
Detailed output from "configure" and eventual "ogr2ogr --formats" appears below.
$ sudo ./configure --with-oci-include=/usr/include/oracle/11.2/client64/ --with-oci-lib=/usr/lib/oracle/11.2/client64/lib -with-pg=/usr/pgsql-9.6/bin/pg_config --with-spatialite=yeschecking build system type... x86_64-pc-linux-gnuchecking host system type... x86_64-pc-linux-gnuchecking for gcc... gccchecking whether the C compiler works... yeschecking for C compiler default output file name... a.outchecking for suffix of executables...checking whether we are cross compiling... nochecking for suffix of object files... ochecking whether we are using the GNU C compiler... yeschecking whether gcc accepts -g... yeschecking for gcc option to accept ISO C89... none neededchecking C_WFLAGS for maximum warnings... -Wall -Wdeclaration-after-statementchecking for g++... g++checking whether we are using the GNU C++ compiler... yeschecking whether g++ accepts -g... yeschecking CXX_WFLAGS for maximum warnings... -Wallchecking whether C compiler accepts -Werror -we10006... nochecking whether C compiler accepts -diag-disable 188,1684,2259,2304,3280,11074,11076... nochecking whether C compiler accepts -Wextra... yeschecking whether C compiler accepts -Winit-self... yeschecking whether C compiler accepts -Wunused-parameter... yeschecking whether C compiler accepts -Wmissing-prototypes... yeschecking whether C compiler accepts -Wmissing-declarations... yeschecking whether C compiler accepts -Wformat... yeschecking whether C compiler accepts -Wformat -Werror=format-security -Wno-format-nonliteral... yeschecking whether C compiler accepts -Wshorten-64-to-32... nochecking whether C compiler accepts -Wlogical-op... yeschecking whether C compiler accepts -Wshadow... yeschecking whether C compiler accepts -Werror=vla... yeschecking whether C compiler accepts -Werror=declaration-after-statement... yeschecking whether C compiler accepts -Wdate-time... nochecking whether C compiler accepts -Wnull-dereference... nochecking whether C compiler accepts -Wduplicated-cond... nochecking whether C++ compiler accepts -Wextra-semi... nochecking whether C compiler accepts -Wno-sign-compare... yeschecking whether C compiler accepts -Wcomma... nochecking whether C compiler accepts -Wfloat-conversion... nochecking whether C compiler accepts -Wdocumentation -Wno-documentation-deprecated-sync... nochecking if -std=gnu89 can be enabled... yeschecking whether C++ compiler accepts -Wunused-private-field... nochecking whether C++ compiler accepts -Wmissing-prototypes... nochecking whether C++ compiler accepts -Wmissing-declarations... yeschecking whether C++ compiler accepts -Wnon-virtual-dtor... yeschecking whether C++ compiler accepts -Wold-style-cast... yeschecking whether C++ compiler accepts -Woverloaded-virtual... yeschecking whether C++ compiler accepts -fno-operator-names... yeschecking whether C++ compiler accepts -Wzero-as-null-pointer-constant... yeschecking if use C++14 compiler options... disabled by userchecking whether g++ supports C++11 features by default... nochecking whether g++ supports C++11 features with -std=c++11... yeschecking whether C++ compiler accepts -Wsuggest-override... nochecking if -Wimplicit-fallthrough can be enabled... nochecking for gcc... (cached) gccchecking whether we are using the GNU C compiler... (cached) yeschecking whether gcc accepts -g... (cached) yeschecking for gcc option to accept ISO C89... (cached) none neededchecking whether we are using the GNU C++ compiler... (cached) yeschecking whether g++ -std=c++11 accepts -g... (cached) yeschecking how to print strings... printfchecking for a sed that does not truncate output... /bin/sedchecking for grep that handles long lines and -e... /bin/grepchecking for egrep... /bin/grep -Echecking for fgrep... /bin/grep -Fchecking for ld used by gcc... /bin/ldchecking if the linker (/bin/ld) is GNU ld... yeschecking for BSD- or MS-compatible name lister (nm)... /bin/nm -Bchecking the name lister (/bin/nm -B) interface... BSD nmchecking whether ln -s works... yeschecking the maximum length of command line arguments... 1572864checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noopchecking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noopchecking for /bin/ld option to reload object files... -rchecking for objdump... objdumpchecking how to recognize dependent libraries... pass_allchecking for dlltool... dlltoolchecking how to associate runtime and link libraries... printf %s\nchecking for ar... archecking for archiver @FILE support... @checking for strip... stripchecking for ranlib... ranlibchecking for gawk... gawkchecking command to parse /bin/nm -B output from gcc object... okchecking for sysroot... nochecking for a working dd... /bin/ddchecking how to truncate binary pipes... /bin/dd bs=4096 count=1checking for mt... nochecking if : is a manifest tool... nochecking how to run the C preprocessor... gcc -Echecking for ANSI C header files... yeschecking for sys/types.h... yeschecking for sys/stat.h... yeschecking for stdlib.h... yeschecking for string.h... yeschecking for memory.h... yeschecking for strings.h... yeschecking for inttypes.h... yeschecking for stdint.h... yeschecking for unistd.h... yeschecking for dlfcn.h... yeschecking for objdir... .libschecking if gcc supports -fno-rtti -fno-exceptions... nochecking for gcc option to produce PIC... -fPIC -DPICchecking if gcc PIC flag -fPIC -DPIC works... yeschecking if gcc static flag -static works... nochecking if gcc supports -c -o file.o... yeschecking if gcc supports -c -o file.o... (cached) yeschecking whether the gcc linker (/bin/ld -m elf_x86_64) supports shared libraries... yeschecking whether -lc should be explicitly linked in... nochecking dynamic linker characteristics... GNU/Linux ld.sochecking how to hardcode library paths into programs... immediatechecking whether stripping libraries is possible... yeschecking if libtool supports shared libraries... yeschecking whether to build shared libraries... yeschecking whether to build static libraries... yeschecking how to run the C++ preprocessor... g++ -std=c++11 -Echecking for ld used by g++ -std=c++11... /bin/ld -m elf_x86_64checking if the linker (/bin/ld -m elf_x86_64) is GNU ld... yeschecking whether the g++ -std=c++11 linker (/bin/ld -m elf_x86_64) supports shared libraries... yeschecking for g++ -std=c++11 option to produce PIC... -fPIC -DPICchecking if g++ -std=c++11 PIC flag -fPIC -DPIC works... yeschecking if g++ -std=c++11 static flag -static works... nochecking if g++ -std=c++11 supports -c -o file.o... yeschecking if g++ -std=c++11 supports -c -o file.o... (cached) yeschecking whether the g++ -std=c++11 linker (/bin/ld -m elf_x86_64) supports shared libraries... yeschecking dynamic linker characteristics... (cached) GNU/Linux ld.sochecking how to hardcode library paths into programs... immediatechecking for std::isnan... yeschecking for dlopen in -ldl... yeschecking for nanosleep in -lrt... yeschecking for sin in -lm... yeschecking for ANSI C header files... (cached) yeschecking assert.h usability... yeschecking assert.h presence... yeschecking for assert.h... yeschecking fcntl.h usability... yeschecking fcntl.h presence... yeschecking for fcntl.h... yeschecking for unistd.h... (cached) yeschecking dbmalloc.h usability... nochecking dbmalloc.h presence... nochecking for dbmalloc.h... nochecking for dlfcn.h... (cached) yeschecking for stdint.h... (cached) yeschecking limits.h usability... yeschecking limits.h presence... yeschecking for limits.h... yeschecking locale.h usability... yeschecking locale.h presence... yeschecking for locale.h... yeschecking values.h usability... yeschecking values.h presence... yeschecking for values.h... yeschecking float.h usability... yeschecking float.h presence... yeschecking for float.h... yeschecking errno.h usability... yeschecking errno.h presence... yeschecking for errno.h... yeschecking direct.h usability... nochecking direct.h presence... nochecking for direct.h... nochecking whether byte ordering is bigendian... nochecking for 64bit integer type... long longchecking for 64bit file io... yeschecking for stat64... yeschecking for fopen64... yeschecking for ftruncate64... yeschecking size of int... 4checking size of unsigned long... 8checking size of void*... 8checking for int8... nochecking for int16... nochecking for int32... nochecking for uintptr_t... yeschecking native cpu bit order... lsb2msbchecking for vprintf... yeschecking for _doprnt... nochecking for snprintf... yeschecking for vsnprintf... yeschecking for atoll... yeschecking for strtof... yeschecking for getcwd... yeschecking whether strtof is declared... yeschecking for readlink... yeschecking for lstat... yeschecking for posix_spawnp... yeschecking for posix_memalign... yeschecking for vfork... yeschecking for mmap... yeschecking for sigaction... yeschecking for statvfs... yeschecking for statvfs64... yeschecking for gmtime_r... yeschecking for localtime_r... yeschecking for uselocale... yeschecking to enable debug build... no, CFLAGS="-g -O2"checking whether GCC 4.1 atomic builtins are available... yeschecking whether GCC bswap builtins are available... yeschecking for __uint128_t... yeschecking whether SSE is available at compile time... yeschecking whether SSSE3 is available at compile time... yeschecking whether AVX is available at compile time... yeschecking to enable LTO (link time optimization) build... nochecking whether we should hide internal symbols... nochecking for local include/lib path... nonechecking for pthread_create in -lpthread... yeschecking for PTHREAD_MUTEX_RECURSIVE... yeschecking for PTHREAD_MUTEX_ADAPTIVE_NP... yeschecking for pthread_spinlock_t... yeschecking for 5 args mremap()... yeschecking for _SC_PHYS_PAGES... yeschecking for deflateInit_ in -lz... nousing internal libz code as deflateInit_ is missingusing internal libz code.checking for ld used by GCC... /bin/ld -m elf_x86_64checking if the linker (/bin/ld -m elf_x86_64) is GNU ld... yeschecking for shared library run path origin... /bin/sh: ./config.rpath: No such file or directorydonechecking for iconv... yeschecking for working iconv... yeschecking for iconv declaration... extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);using ICONV_CPP_CONST=""checking for ZSTD_decompressStream in -lzstd... nolibzstd not found - ZSTD support disabledchecking for PostgreSQL... yeschecking for PQconnectdb in -lpq... yeschecking for G_gisinit_2 in -lgrass5... nochecking for ffopen in -lcfitsio... nolibcfitsio not found - FITS support disabledchecking for Mopen in -lcsf... nochecking csf.h usability... nochecking csf.h presence... nochecking for csf.h... nousing internal csf code.checking for libpng... checking for png_set_IHDR in -lpng... nochecking png.h usability... nochecking png.h presence... nochecking for png.h... nousing internal png code.checking for libcrunch... dds support disabled.checking for gta_version in -lgta... nolibgta not found - GTA support disabledchecking for PCIDSK... using internal libpcidsk.checking for libtiff... checking for TIFFScanlineSize64 in -ltiff... nousing internal TIFF code.BigTIFF support enabled.using internal GeoTIFF code.checking for jpeg_read_scanlines in -ljpeg... nochecking jpeglib.h usability... nochecking jpeglib.h presence... nochecking for jpeglib.h... nousing internal jpeg code.checking CharLS/interface.h usability... nochecking CharLS/interface.h presence... nochecking for CharLS/interface.h... nochecking for jpeg12... enabledchecking for DGifOpenFileName in -lgif... nochecking gif_lib.h usability... nochecking gif_lib.h presence... nochecking for gif_lib.h... nousing internal gif code.checking ecs.h usability... nochecking ecs.h presence... nochecking for ecs.h... nochecking for FMEObjects... noSOSI support disabled.checking for MongoCXX... MongoCXX not found.checking for SDreaddata in -lmfhdfalt... nochecking for SDreaddata in -lmfhdf... nochecking for SDreaddata in -lhdf4... nochecking for SDreaddata in -lmfhdf... nochecking for SDreaddata in -lmfhdf... nochecking for pkg-config... /bin/pkg-configchecking pkg-config is at least version 0.21... yeschecking for HDF5... nochecking for H5Fopen in -lhdf5... nochecking for kea-config... nochecking for kea... nochecking for nc-config... no did not find nc-config, some features may be missing use --with-netcdf=/path/to/netcdf or add nc-config to PATHchecking for nc_open in -lnetcdf... nolibnetcdf not found ... netCDF support disabledchecking for jpc_decode in -ljasper... nochecking for jp2_decode in -ljasper... nochecking for pgx_decode in -ljasper... nochecking for pkg-config... (cached) /bin/pkg-configchecking pkg-config is at least version 0.21... yeschecking for OPENJPEG... nochecking for FileGDBAPI... FileGDBAPI not found.checking for NCScbmOpenFileView in -lNCSEcw... nochecking for NCScbmOpenFileView in -lecwj2... nochecking for Kakadu JPEG2000 support... not requested.configure: MrSID support disabled.configure: MrSID/MG4 Lidar support disabled.checking for JP2Lura support... checking for MSG... not requestedchecking for BSB... enabledchecking for Oracle OCI headers in /usr/include/oracle/11.2/client64/... yeschecking for Oracle OCI libraries in /usr/lib/oracle/11.2/client64/lib... yeschecking if Oracle OCI version is >= 10.0.1 ... yeschecking for Oracle version >= 10.x to use -lnnz10 flag... yeschecking if Oracle support is enabled... yeschecking for GRIB... enabledenabledchecking for MySQL... nochecking for Ingres... nochecking for Xerces C++ Parser... nochecking for Expat XML Parser... nochecking for pkg-config... (cached) /bin/pkg-configchecking pkg-config is at least version 0.21... yeschecking for LIBKML... nochecking for Google libkml... nocheck for unixODBCchecking for SQLConnect in -lodbc... yeschecking for SQLInstallDriverEx in -lodbcinst... yeschecking for sql.h... nosql.h not foundchecking for Oracle OCI headers in /usr/include/oracle/11.2/client64/... yeschecking for Oracle OCI libraries in /usr/lib/oracle/11.2/client64/lib... yeschecking if Oracle OCI version is >= 8.1.7 ... yeschecking for Oracle version >= 10.x to use -lnnz10 flag... yeschecking if Oracle support is enabled... yeschecking for DODS... disabledchecking for curl-config... nochecking for xml2-config... nochecking for spatialite... checking sqlite3.h usability... yeschecking sqlite3.h presence... yeschecking for sqlite3.h... yeschecking for spatialite.h in /usr/include or /usr/local/include... foundchecking for spatialite_init in -lspatialite... yeschecking for spatialite_target_cpu in -lspatialite... nochecking for sqlite3_column_table_name in -lsqlite3... yesconfigure: rasterlite2 support disabledchecking pcre.h usability... nochecking pcre.h presence... nochecking for pcre.h... nochecking Checking for Teigha... disabledconfigure: IBM Informix DataBlade not supported.configure: checking whether we should include ESRI SDE support... ESRI SDE support not requested.checking for WebPDecodeRGB in -lwebp... nolibwebp not found - WEBP support disabledchecking for geos-config... nochecking for sfcgal-config... nochecking qhull/libqhull.h usability... nochecking qhull/libqhull.h presence... nochecking for qhull/libqhull.h... nochecking libqhull/libqhull.h usability... nochecking libqhull/libqhull.h presence... nochecking for libqhull/libqhull.h... nochecking for OpenCL support... nochecking for FreeXL support... checking freexl.h usability... nochecking freexl.h presence... nochecking for freexl.h... nochecking for freexl_open in -lfreexl... nochecking for freexl_open in -lfreexl... nochecking for freexl_open in -lfreexl... nochecking for freexl_open in -lfreexl... nochecking for freexl_open in -lfreexl... nolibfreexl not found - FreeXL support disabledchecking for json_object_set_serializer in -ljson-c... nousing internal libjson-c codechecking whether to enable PAM... yeschecking whether to build PDF driver as a plugin... nochecking for poppler... disabledchecking for podofo... disabledchecking for pdfium... disabledchecking how to link PROJ library... link dynamically.checking GDAL version information from gdal_version.h.in: 2.3.2checking for perl bindings... disabledchecking for php bindings... disabledchecking for python bindings... disabledchecking whether we should include Java support... nochecking whether we should include MDB support... noconfigure: checking whether we should include rasdaman support... rasdaman support not requested.checking whether we should include Armadillo support... nochecking for cryptopp... nochecking for crypto... checking for EVP_sha256 in -lcrypto... nochecking for MRF... enabledchecking for NULL... disabledchecking if sprintf can be overloaded for GDAL compilation... yesconfigure: creating ./config.statusconfig.status: creating GDALmake.optconfig.status: WARNING: 'GDALmake.opt.in' seems to ignore the --datarootdir settingconfig.status: creating port/cpl_config.hconfig.status: port/cpl_config.h is unchangedconfig.status: executing libtool commands
GDAL is now configured for x86_64-pc-linux-gnu
Installation directory: /usr/local C compiler: gcc -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2 C++ compiler: g++ -std=c++11 -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2 C++14 support: no
LIBTOOL support: yes
LIBZ support: internal LIBLZMA support: no ZSTD support: no cryptopp support: no crypto/openssl support: no GRASS support: no CFITSIO support: no PCRaster support: internal LIBPNG support: internal DDS support: no GTA support: no LIBTIFF support: internal (BigTIFF=yes) LIBGEOTIFF support: internal LIBJPEG support: internal 12 bit JPEG: yes 12 bit JPEG-in-TIFF: yes LIBGIF support: internal JPEG-Lossless/CharLS: no OGDI support: no HDF4 support: no HDF5 support: no Kea support: no NetCDF support: no Kakadu support: no JasPer support: no OpenJPEG support: no ECW support: no MrSID support: no MrSID/MG4 Lidar support: no JP2Lura support: no MSG support: no GRIB support: yes EPSILON support: no WebP support: no cURL support (wms/wcs/...):no PostgreSQL support: yes MRF support: yes MySQL support: no Ingres support: no Xerces-C support: no NAS support: no Expat support: no libxml2 support: no Google libkml support: no ODBC support: no PGeo support: no FGDB support: no MDB support: no PCIDSK support: internal OCI support: yes GEORASTER support: yes SDE support: no Rasdaman support: no DODS support: no SQLite support: yes PCRE support: no SpatiaLite support: yes RasterLite2 support: no Teigha (DWG and DGNv8): no INFORMIX DataBlade support:no GEOS support: no SFCGAL support: no QHull support: internal Poppler support: no Podofo support: no PDFium support: no OpenCL support: no Armadillo support: no FreeXL support: no SOSI support: no MongoDB support: no
SWIG Bindings: no
Statically link PROJ: no enable GNM building: yes enable pthread support: yes enable POSIX iconv support:yes hide internal symbols: no
Supported Formats: PCIDSK -raster,vector- (rw+v): PCIDSK Database File PDF -raster,vector- (w+): Geospatial PDF MBTiles -raster,vector- (rw+v): MBTiles ESRI Shapefile -vector- (rw+v): ESRI Shapefile MapInfo File -vector- (rw+v): MapInfo File UK .NTF -vector- (rov): UK .NTF OGR_SDTS -vector- (rov): SDTS S57 -vector- (rw+v): IHO S-57 (ENC) DGN -vector- (rw+v): Microstation DGN OGR_VRT -vector- (rov): VRT - Virtual Datasource REC -vector- (ro): EPIInfo .REC Memory -vector- (rw+): Memory BNA -vector- (rw+v): Atlas BNA CSV -vector- (rw+v): Comma Separated Value (.csv) GML -vector- (rw+v): Geography Markup Language (GML) GPX -vector- (rw+v): GPX KML -vector- (rw+v): Keyhole Markup Language (KML) GeoJSON -vector- (rw+v): GeoJSON ESRIJSON -vector- (rov): ESRIJSON TopoJSON -vector- (rov): TopoJSON OGR_GMT -vector- (rw+v): GMT ASCII Vectors (.gmt) WAsP -vector- (rw+v): WAsP .map format PostgreSQL -vector- (rw+): PostgreSQL/PostGIS OCI -vector- (rw+): Oracle Spatial OpenFileGDB -vector- (rov): ESRI FileGDB XPlane -vector- (rov): X-Plane/Flightgear aeronautical data DXF -vector- (rw+v): AutoCAD DXF CAD -raster,vector- (rovs): AutoCAD Driver Geoconcept -vector- (rw+v): Geoconcept GeoRSS -vector- (rw+v): GeoRSS GPSTrackMaker -vector- (rw+v): GPSTrackMaker PGDUMP -vector- (w+v): PostgreSQL SQL dump GPSBabel -vector- (rw+): GPSBabel SUA -vector- (rov): Tim Newport-Peace's Special Use Airspace Format OpenAir -vector- (rov): OpenAir OGR_PDS -vector- (rov): Planetary Data Systems TABLE HTF -vector- (rov): Hydrographic Transfer Vector AeronavFAA -vector- (rov): Aeronav FAA EDIGEO -vector- (rov): French EDIGEO exchange format SVG -vector- (rov): Scalable Vector Graphics Idrisi -vector- (rov): Idrisi Vector (.vct) ARCGEN -vector- (rov): Arc/Info Generate SEGUKOOA -vector- (rov): SEG-P1 / UKOOA P1/90 SEGY -vector- (rov): SEG-Y SXF -vector- (rov): Storage and eXchange Format Selafin -vector- (rw+v): Selafin JML -vector- (rw+v): OpenJUMP JML VDV -vector- (rw+v): VDV-451/VDV-452/INTREST Data Format MVT -vector- (rov): Mapbox Vector Tiles TIGER -vector- (rw+v): U.S. Census TIGER/Line AVCBin -vector- (rov): Arc/Info Binary Coverage AVCE00 -vector- (rov): Arc/Info E00 (ASCII) Coverage
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190809/16c75c1b/attachment-0001.html>
