[gdal-dev] Requirements for GPKG support in ogr2ogr build?
Even Rouault
even.rouault at spatialys.com
Fri Aug 9 00:48:56 PDT 2019
On vendredi 9 août 2019 03:07:04 CEST WhiskyPiper67 wrote:
> SQLite support
Make sure you "make clean" before rebuilding after each change in ./configure
flags and/or new package new installed. Given that there is "SQLite support:
yes" in the configure output, that should do it
http://www.spatialys.com
