[gdal-dev] Requirements for GPKG support in ogr2ogr build?
WhiskyPiper67 whiskypiper67 at yahoo.com
Fri Aug 9 01:57:01 PDT 2019
 Oh wow...  Rookie error!
Thank you very much for setting me straight, Even.
"make clean" did the trick.
  GPKG -raster,vector- (rw+vs): GeoPackage
That's what I'm after!!
Cheers,
Dave
    On Friday, 9 August 2019, 05:48:59 pm AEST, Even Rouault <even.rouault at spatialys.com> wrote:
 On vendredi 9 août 2019 03:07:04 CEST WhiskyPiper67 wrote:
> SQLite support
Make sure you "make clean" before rebuilding after each change in ./configure
flags and/or new package new installed. Given that there is "SQLite support:
yes" in the configure output, that should do it
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190809/7c20ff0d/attachment.html>
