[gdal-dev] ogr2ogr -tps with more than 1000 control points
Jan Hartmann
j.l.h.hartmann at uva.nl
Fri Aug 9 04:31:57 PDT 2019
Hi all,
I'm converting large historical vector maps with ogr2ogr, using -gcp and
-tps to rubbersheet the polygons with control points. Works fine up to
about a thousand control points, each in the form of "-gcp fromx fromy
tox toy". After that, the converted map becomes erratic. Is this a bug?
BTW, I am using gdal 2.1.0
Regards,
Jan Hartmann
Amsterdam
