[gdal-dev] [EXTERNAL] Re: gdalinfo not reading vertical datum information?
Greif, Jeremiah jgreif at usgs.gov
Thu Aug 15 13:45:52 PDT 2019
Thanks for the quick response, that worked great.  That is exciting news
regarding geotiff 1.1, should simply things a bit
On Thu, Aug 15, 2019 at 12:31 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 15 août 2019 09:52:22 CEST Greif, Jeremiah wrote:
> > I recently had a situation where i needed to add a vertical crs to a
> raster
> > file.  I did what have done many times and use *gdal_translate -a_srs
> > epsg:6350+5703 *to add the navd88 vertical datum to the raster file.
> When
> > I read the file to double check my work using gdalinfo i get the
> folllowing
> > results which doesn't include the vertcrs infomation.
> > [image: gdal_post_vrtcrs.PNG]
> > When I look at the new raster file in Arc as well as the open source
> > tiffinfo I do see that the gdal did in fact write the vertcrs into the
> > file.  Why is gdalinfo not reading it though? has something changed in
> the
> > way the tags are written/read with a recent release?
> No, this has always been the behaviour of the GTiff driver. It does write
> CompoundCRS, but on reading it only exposes the horizontal part, by
> default.
> This behaviour can be changed by setting the configuratin
> option/environment
> variable GTIFF_REPORT_COMPD_CS to YES
> See
> https://gdal.org/drivers/raster/gtiff.html#configuration-options
> Note: for the new geotiff 1.1 specification (currently under vote at OGC),
> for
> a file with geotiff 1.1 version number in it, the Compound CRS will be
> reported by default
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Jeremiah Greif
Geographer
USGS - NGTOC
(303) 202-4510
jgreif at usgs.gov
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190815/e18cc23a/attachment.html>
