[gdal-dev] "Banning" use of underflow/overflow with unsigned integer arithmetic ?
Even Rouault
even.rouault at spatialys.com
Fri Aug 16 10:28:42 PDT 2019
I've a PR ready that might be a bit controversial among contributors as it
effectively "bans" a well-defined behaviour of C/C++, that is underflow/
overflow on unsigned integer arithmetic. However there are potential for real
bugs to be hidden by such a behaviour (I or other contributors fixed a few
instances of that in a few previous commits), so it seems reasonable to try to
avoid it when possible, and when not possible, to tag the functions where this
is explicitly allowed with CPL_NOSANITIZE_UNSIGNED_INT_OVERFLOW
See
https://github.com/OSGeo/gdal/pull/1782
Even
http://www.spatialys.com
