[gdal-dev] Python IOError during file object destructor
Even Rouault
even.rouault at spatialys.com
Wed Aug 21 04:03:15 PDT 2019
Craig,
gdal.GDALDestroyDriverManager() exists in the SWIG binding but I would
definitely not recommend using it. At best, it will be a no-op. At worst, this
will result in double free of datasets.
The only situations I can think of where you would have still-alive GDAL
datasets at Python process close are:
- global variables storing datasets
- main program exiting with still open datasets.
And in both cases, calling explicitly gdal.GDALDestroyDriverManager() will
result in a crash
Demo:
given test.py being
from osgeo import gdal
# ds will be released when f() returns
def f():
ds = gdal.Open('../autotest/gcore/data/byte.tif')
f()
print('foo')
print('bar')
$ CPL_DEBUG=ON python test.py
GDAL: GDALOpen(../autotest/gcore/data/byte.tif, this=0x18eaa00) succeeds as
GTiff.
GDAL: GDALClose(../autotest/gcore/data/byte.tif, this=0x18eaa00)
foo
GTiff.
GDAL: Force close of ../autotest/gcore/data/byte.tif (0x18eaa00) in
GDALDriverManager cleanup.
bar
GDAL: In ~GDALMajorObject on invalid object
*** Error in `python': corrupted size vs. prev_size: 0x00000000018eae30 ***
======= Backtrace: =========
[... crash ...]
Even
http://www.spatialys.com
