[gdal-dev] Motion: adopt RFC 76 OGR Python drivers
deduikertjes
DeDuikertjes at xs4all.nl
Mon Dec 9 09:10:40 PST 2019
RFC76 implementation is now available in master
Even
I used the Dockerfile from
https://github.com/OSGeo/gdal/tree/master/gdal/docker/ubuntu-full
to build a container from master. I copied in all example drivers and an
example cityjson file.
In this I ran the autotest pytest -vvs ogr/ succesfully.
However, trying to use the drivers from command line fails.
I've tried things like
gdalinfo --config GDAL_PYTHON_DRIVER_PATH ./pydrivers/ --formats | grep
DUMMY
gdalinfo --config GDAL_PYTHON_DRIVER_PATH "/python_drivers/" --formats |
grep JSON
gdalinfo --config GDAL_PYTHON_DRIVER_PATH "/python_drivers/" test.json
All these are failing. The first two don't have any of the example drivers
in the format list, the last fails with the well know error for not having
the correct driver for the dataset.
What am I doing wrong?
Thanks, MArco
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
