[gdal-dev] Motion: adopt RFC 76 OGR Python drivers
Even Rouault
even.rouault at spatialys.com
Mon Dec 9 09:23:37 PST 2019
Marco,
> I used the Dockerfile from
> https://github.com/OSGeo/gdal/tree/master/gdal/docker/ubuntu-full
> to build a container from master. I copied in all example drivers and an
> example cityjson file.
> In this I ran the autotest pytest -vvs ogr/ succesfully.
> However, trying to use the drivers from command line fails.
> I've tried things like
> gdalinfo --config GDAL_PYTHON_DRIVER_PATH ./pydrivers/ --formats | grep
> DUMMY
> gdalinfo --config GDAL_PYTHON_DRIVER_PATH "/python_drivers/" --formats |
> grep JSON
> gdalinfo --config GDAL_PYTHON_DRIVER_PATH "/python_drivers/" test.json
> All these are failing. The first two don't have any of the example drivers
> in the format list, the last fails with the well know error for not having
> the correct driver for the dataset.
> What am I doing wrong?
Probably some issue with the path you set:
>From the gdal/ subdirectory of a git checkout of GDAL, the following
$ docker run --rm -v /home:/home osgeo/gdal:ubuntu-full-latest ogrinfo --config GDAL_PYTHON_DRIVER_PATH $PWD/examples/pydrivers --format CityJSON
returns
Format Details:
Short Name: CityJSON
Long Name: CityJSON
Supports: Vector
Extension: json
Supports: Open() - Open existing dataset.
Supports: Virtual IO - eg. /vsimem/
Other metadata items:
DRIVER_LANGUAGE=PYTHON
Even
http://www.spatialys.com
