[gdal-dev] Motion: adopt RFC 76 OGR Python drivers
Marco
deduikertjes at xs4all.nl
Mon Dec 9 09:35:59 PST 2019
Even,
Thanks but ...
xxxx/gdal$ docker run --rm -v /home:/home osgeo/gdal:ubuntu-full-latest
ogrinfo --config GDAL_PYTHON_DRIVER_PATH $PWD/examples/pydrivers
--format CityJSON
ERROR 1: --format option given with format 'CityJSON', but that format not
recognised. Use the --formats option to get a list of available formats,
and use the short code (i.e. GTiff or HFA) as the format identifier.
I did try all sorts of quoting of options and so on with the expected
variety of error messages.
(Docker version 18.09.5, build e8ff056)
Marco
On 09-12-19 18:23, Even Rouault wrote:
> Marco,
>> I used the Dockerfile from
>> https://github.com/OSGeo/gdal/tree/master/gdal/docker/ubuntu-full
>> to build a container from master. I copied in all example drivers and an
>> example cityjson file.
>> In this I ran the autotest pytest -vvs ogr/ succesfully.
>> However, trying to use the drivers from command line fails.
>> I've tried things like
>> gdalinfo --config GDAL_PYTHON_DRIVER_PATH ./pydrivers/ --formats | grep
>> DUMMY
>> gdalinfo --config GDAL_PYTHON_DRIVER_PATH "/python_drivers/" --formats |
>> grep JSON
>> gdalinfo --config GDAL_PYTHON_DRIVER_PATH "/python_drivers/" test.json
>> All these are failing. The first two don't have any of the example drivers
>> in the format list, the last fails with the well know error for not having
>> the correct driver for the dataset.
>> What am I doing wrong?
> Probably some issue with the path you set:
> From the gdal/ subdirectory of a git checkout of GDAL, the following
> $ docker run --rm -v /home:/home osgeo/gdal:ubuntu-full-latest ogrinfo --config GDAL_PYTHON_DRIVER_PATH $PWD/examples/pydrivers --format CityJSON
> returns
> Format Details:
> Short Name: CityJSON
> Long Name: CityJSON
> Supports: Vector
> Extension: json
> Supports: Open() - Open existing dataset.
> Supports: Virtual IO - eg. /vsimem/
> Other metadata items:
> DRIVER_LANGUAGE=PYTHON
> Even
