[gdal-dev] Different results when reading a GeoTIFF with GDAL 2.1.2 vs 3.x
Even Rouault even.rouault at spatialys.com
Sun Dec 29 13:18:08 PST 2019
On dimanche 29 décembre 2019 22:04:23 CET Momtchil Momtchev wrote:
>      That was my first idea too so I rebuilt without SSE,
--without-sse will have no effect on a 64-bit build on the part of the code
I'm suspecting (it only affects gdal_grid). As all Intel/AMD CPUs supporting
64-bit have SSE and SSE2, SSE2 optimizations are unconditionally enabled.
In gcore/rasterio.cpp, can you change line 2869
#if (defined(__x86_64) || defined(_M_X64)) &&  !(defined(__GNUC__) && __GNUC__
< 4)
to
#if 0
to remove any SSE2 (and SSSE3) optimization ?
http://www.spatialys.com
