[gdal-dev] Different results when reading a GeoTIFF with GDAL 2.1.2 vs 3.x
Momtchil Momtchev
momtchil at momtchev.com
Sun Dec 29 13:36:24 PST 2019
Disabling HAVE_SSSE3_AT_COMPILE_TIME had no effect, but after
short-circuiting the #ifdef I got a correct result.
On 29/12/2019 22:18, Even Rouault wrote:
> On dimanche 29 décembre 2019 22:04:23 CET Momtchil Momtchev wrote:
>> That was my first idea too so I rebuilt without SSE,
> --without-sse will have no effect on a 64-bit build on the part of the code
> I'm suspecting (it only affects gdal_grid). As all Intel/AMD CPUs supporting
> 64-bit have SSE and SSE2, SSE2 optimizations are unconditionally enabled.
> In gcore/rasterio.cpp, can you change line 2869
> #if (defined(__x86_64) || defined(_M_X64)) && !(defined(__GNUC__) && __GNUC__
> < 4)
> to
> #if 0
> to remove any SSE2 (and SSSE3) optimization ?
Momtchil Momtchev <momtchil at momtchev.com>
