[gdal-dev] PROJ6?
Darafei "Komяpa" Praliaskouski
me at komzpa.net
Fri Feb 1 12:20:58 PST 2019
Hello,
I can't rebuild gdal master with proj master as update of PostGIS env.
Build scripts are unchanged and are from
https://github.com/postgis/postgis-build-env. Here's tail of build log:
checking whether SSE is available at compile time... yes
checking whether SSSE3 is available at compile time... yes
checking whether AVX is available at compile time... yes
checking to enable LTO (link time optimization) build... no
checking whether we should hide internal symbols... no
checking for local include/lib path... none
checking for pthread_create in -lpthread... yes
checking for PTHREAD_MUTEX_RECURSIVE... yes
checking for PTHREAD_MUTEX_ADAPTIVE_NP... yes
checking for pthread_spinlock_t... yes
checking for 5 args mremap()... yes
checking for _SC_PHYS_PAGES... yes
checking for deflateInit_ in -lz... yes
checking for inflateCopy in -lz... yes
using pre-installed libz
checking for ld used by GCC... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... /bin/bash: ./config.rpath:
No such file or directory
done
checking for iconv... yes
checking for working iconv... yes
checking for iconv declaration...
extern size_t iconv (iconv_t cd, char * *inbuf, size_t
*inbytesleft, char * *outbuf, size_t *outbytesleft);
using ICONV_CPP_CONST=""
checking for PROJ >= 6 library... checking for proj_create_from_wkt in
-lproj... no
checking for internal_proj_create_from_wkt in -lproj... no
checking for internal_proj_create_from_wkt in -linternalproj... no
configure: error: PROJ 6 symbols not found
The command '/bin/sh -c git clone --depth 1 --branch ${GDAL_BRANCH}
https://github.com/OSGeo/gdal && cd gdal/gdal && ./autogen.sh &&
./configure && make -j${BUILD_THREADS} && make install && cd /src && rm
-rf gdal' returned a non-zero code: 1
File "build.py", line 84, in <module>
File "/usr/lib/python3.6/subprocess.py", line 291, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['docker', 'build', '--pull',
'--build-arg', 'BUILD_DATE=20190201', '--build-arg',
'POSTGRES_BRANCH=master', '--build-arg', 'GEOS_BRANCH=master',
'--build-arg', 'GDAL_BRANCH=master', '--build-arg', 'PROJ_BRANCH=master',
'-t', 'postgis/postgis-b
uild-env:latest', '.']' returned non-zero exit status 1.
On Fri, Feb 1, 2019 at 11:18 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 1 février 2019 19:57:45 CET Alan Stewart wrote:
> > OJ6. I assume this is version 6 of proj4.org? This does not seem to be
> > available on their website.
> PROJ 6 is not yet released. You need to use the master branch of
> https://github.com/OSGeo/proj.4/
> (In case you missed it, this is as consequence of the recently adopted
> https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn )
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190201/4d0f84cd/attachment.html>
