[gdal-dev] PROJ6?
Michael Smith
michael.smith.erdc at gmail.com
Fri Feb 1 12:24:32 PST 2019
You need to change your build order, you need to build proj before you build gdal.
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Komяpa Darafei Praliaskouski <me at komzpa.net>
Date: Friday, February 1, 2019 at 3:21 PM
To: Even Rouault <even.rouault at spatialys.com>
Cc: <gdal-dev at lists.osgeo.org>, Alan Stewart <astewart at terragotech.com>
Subject: Re: [gdal-dev] PROJ6?
Hello,
I can't rebuild gdal master with proj master as update of PostGIS env.
Build scripts are unchanged and are from https://github.com/postgis/postgis-build-env. Here's tail of build log:
checking whether SSE is available at compile time... yes
checking whether SSSE3 is available at compile time... yes
checking whether AVX is available at compile time... yes
checking to enable LTO (link time optimization) build... no
checking whether we should hide internal symbols... no
checking for local include/lib path... none
checking for pthread_create in -lpthread... yes
checking for PTHREAD_MUTEX_RECURSIVE... yes
checking for PTHREAD_MUTEX_ADAPTIVE_NP... yes
checking for pthread_spinlock_t... yes
checking for 5 args mremap()... yes
checking for _SC_PHYS_PAGES... yes
checking for deflateInit_ in -lz... yes
checking for inflateCopy in -lz... yes
using pre-installed libz
checking for ld used by GCC... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... /bin/bash: ./config.rpath: No such file or directory
done
checking for iconv... yes
checking for working iconv... yes
checking for iconv declaration...
extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
using ICONV_CPP_CONST=""
checking for PROJ >= 6 library... checking for proj_create_from_wkt in -lproj... no
checking for internal_proj_create_from_wkt in -lproj... no
checking for internal_proj_create_from_wkt in -linternalproj... no
configure: error: PROJ 6 symbols not found
The command '/bin/sh -c git clone --depth 1 --branch ${GDAL_BRANCH} https://github.com/OSGeo/gdal && cd gdal/gdal && ./autogen.sh && ./configure && make -j${BUILD_THREADS} && make install && cd /src && rm -rf gdal' returned a non-zero code: 1
File "build.py", line 84, in <module>
File "/usr/lib/python3.6/subprocess.py", line 291, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['docker', 'build', '--pull', '--build-arg', 'BUILD_DATE=20190201', '--build-arg', 'POSTGRES_BRANCH=master', '--build-arg', 'GEOS_BRANCH=master', '--build-arg', 'GDAL_BRANCH=master', '--build-arg', 'PROJ_BRANCH=master', '-t', 'postgis/postgis-b
uild-env:latest', '.']' returned non-zero exit status 1.
On Fri, Feb 1, 2019 at 11:18 PM Even Rouault <even.rouault at spatialys.com> wrote:
On vendredi 1 février 2019 19:57:45 CET Alan Stewart wrote:
> OJ6. I assume this is version 6 of proj4.org? This does not seem to be
> available on their website.
PROJ 6 is not yet released. You need to use the master branch of
https://github.com/OSGeo/proj.4/
(In case you missed it, this is as consequence of the recently adopted
https://trac.osgeo.org/gdal/wiki/rfc73_proj6_wkt2_srsbarn )
Even
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
Support me: http://patreon.com/komzpa
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190201/5631c468/attachment-0001.html>
